SliceString Revised
Wouter
VI Name:
SliceString
Total VIs:
2
Description:
The slice string should in my opinion by revised. Currently it is not doing as the name implies it thus. Because it only fetches the subset of a string, which can already be done by the "string subset" function in LabVIEW, the only thing it really does is calculating the length. Because one gives 2 indices, i:j, then length is j-i.
My two VI's are different. They accept a array of indices and then slice them on those places and index the results in a array of strings. Further the other VI accepts a numeric input and then slices the string after each repetition. The end VI should be polymorfic. (The slice string by reptition is in fact the same as the StringToChar function.
Note:
Blockdiagram:
Slice string by indices
Slice string by repitition
What are you thoughts on this VI?
  • Would you like to see such a function in OpenG?
  • Can you optimize the code?
  • In which package should it be included?
  • Should it be rejected?
ps. the snippts are in 2011, the VI's in 2009
SliceStringByIndices.vi
SliceStringByRepetition.vi
I am unaware of the history of the OpenG Slice String VI (maybe someone else could comment) but you can see from the Context Help that is has Python origins.
Additionally, I know other languages, e.g js, has both a slice and substring function too.
And whilst you are correct that the end result could be obtained using either function (e.g. use either function to get 'BC' from 'ABCD') - each function has it's differences (and preferred use cases). E.g. Slice string accepts negative numbers to index backward from the end of the string etc...
However both work on Strings as opposed to String Arrays (as per your proposal) so (aside from the above) I think it would be better suggesting a new VI as opposed to revising and replacing the existing Slice String VI.
