EvanC Posted January 25, 2012 Report Posted January 25, 2012 I am not sure where to post this put I have been using the Base64 VIs from http://wiki.openg.org/OpenG_Internet_Connectivity_Tools that I have also seen referenced in these forums and there is a bug. If you try to encode an empty string it hits an infinite loop and you run out of memory. So FYI.... Its not hard to fix I just wanted to put it out there for general consumption. Quote
jgcode Posted January 26, 2012 Report Posted January 26, 2012 What version are your changes in? Uploading them here would be a great start. Quote
