nightdweller Posted October 18, 2004 Report Posted October 18, 2004 GUI gurus, I desperately need your help.. Okay I'm exaggerating, but I do need your help. You know that digital display for the charts. I want to vertical align that with the legend. Apparently when it changes it loses it's vertical alignment. Is there a way I can fix this? Or would I have customize a digital display, ie a picture. Quote
aledain Posted October 19, 2004 Report Posted October 19, 2004 I want to vertical align that with the legend. 2366[/snapback] Doesn't turning off Y scale autoscaling work? You could then programatically set the top and bottom shown plot. N.B. I haven't tried it but IMHO it should work this way. cherrs, Alex Quote
nightdweller Posted October 19, 2004 Author Report Posted October 19, 2004 Doesn't turning off Y scale autoscaling work? You could then programatically set the top and bottom shown plot.N.B. I haven't tried it but IMHO it should work this way. cherrs, Alex 2370[/snapback] I will give that a try, but here is a picture of what I mean. Anyhow, apparently I can get it to align if I resize the font. The problem is that it gets too small to read. Quote
todd Posted October 19, 2004 Report Posted October 19, 2004 Perhaps you could use "Position" and "Legend -> Position" waveform graph properties. I use these to calculate a new position for the legend when programmatically adding plots to a graph. Quote
nightdweller Posted October 19, 2004 Author Report Posted October 19, 2004 Perhaps you could use "Position" and "Legend -> Position" waveform graph properties. I use these to calculate a new position for the legend when programmatically adding plots to a graph. 2393[/snapback] I actually was just looking into that. Maybe I can resize the legend... I guess I will give that a try. Thanx. Quote
nightdweller Posted October 21, 2004 Author Report Posted October 21, 2004 Well fellas... I tried your suggestions, but it didn't work as plan . Also, Resizing the legend would just add or remove elements because each legend element has a predefined height size, for example 21. The size of four elements would be 84. If we can pre define the individual height of the legend element, then we could adjust it. Any suggestions?? Maybe there's something I can set in LV?? Thanx. Quote
Michael Aivaliotis Posted October 22, 2004 Report Posted October 22, 2004 I will give that a try, but here is a picture of what I mean. Anyhow, apparently I can get it to align if I resize the font. The problem is that it gets too small to read. 2385[/snapback] Why not just increase the Font size of the legend only? Seems to work for me. Quote
nightdweller Posted October 22, 2004 Author Report Posted October 22, 2004 Why not just increase the Font size of the legend only? Seems to work for me. 2434[/snapback] I did try this before you posted Although I can't get the same solution. :headbang: Hmm.. Guru's like you always seem to have a solution :worship: I'm not worthy I was just wondering how you manage to get the font size to change with the object(legend item) to rescale it's size?? It doesn't work for me ctrl +++?? maybe a dumb question thanx Quote
