MUX the DUT Signals
I have a DMM for measuring the DUT's different voltages.
My DUT has multiple voltages so i need to measure all in single DMM.
Can anybody give me link or let me know how i can MUX all my DUT signals so that the DMM will measure one at a time sequentially. \
Accordingly i will acquire the measured value through GPIB.
Is any cheap readymade MUX card available (Non NI product also OK) share with me.
I never tried this before,, so any tutorial link also highly recommended.
Thanks.
Rather than a MUX, I'd suggest you take a look at a switch matrix - if you're doing 2-point measurements (ie: only using the +ve and -ve probes of your DMM) then you need a 2xN matrix, where N is the number of test points. Then, depending on what your development environment is (LabVIEW vs TestStand), you can set up switch routes in Swtich Executive and switch as needed.
PS: you mentioned non-NI cards: while I try to use NI cards where I can, if there's something outside of their range that I need to do, I choose a card that is IVI-Switch compatible, so I can still use NI Switch Executive. eg: Pickering.
