LabVIEW Load Error Code 1
Hi guys,
Yesterday, I was troubleshooting my code for memory leaks. Then, a "Memory is full" dialog box popped up. I clicked OK and tried to save the VI. The same dialog box popped up again but this time, LabVIEW crashed after I clicked OK. As a result, I now could not open my VI - everytime I tried, I got the LabVIEW Load Error Code 1 message (see attached). I tried to open this VI (also attached) from another computer and the result is still the same. Is there any way this file can be recovered?
I really hope that there's light to this issue.
Thanks.
Shazlan
Signal Module.vi
Holding down <crtl> + <shift> and clicking the run button will force a binary compile of the VIs and all it's dependencies. This can get you out of situations like this. Retrieving from a backup is a good idea.
