Read From file
I want to read data from a text file. The text file consists of data set out in lines, as below:
Sat 23/10/2004 The coordinates (64.822, 1.770) were recorded at 23/10/2004 21:25:48
I'm then using a scan from string function in order to extract the coordinate pairs 64.822, 1.770 into an array...
The read from file works fine, its gettin the data into the array which is causin problems. It should read the coordinates from each line, extracting the cordinates to an array.
I can get the scan from string to add the coordinates from the 1st line of the file into the array, but it doesnt seem to be moving onto the next line of the file?
I'm quite new to this lab view thing.
ANy help?
Regards
:wacko:
I sorted it myself in the end. :thumbup:
I used a for loop and a 'pick line' function to read each individual line at a time from the
file.
Sweet
Its really simple now, but i didnt know about the 'pick line' function lol.
Does anyone know of a different solution, without using pick line??
Thanks
