Secondary Monitor Resolution
Hi All
I have an application where I require 2x monitors running under XP (in an extended desktop). I need to programmatically set the resolution of the secondary monitor - and at the same time leaving the primary monitor in its usual resolution. I understand that the ChangeDisplaySettingsEx fn can be used to do this via User32.dll. Can someone point me to an example vi on how this might be achieved please. Many thanks :worshippy:
Thanks for the quick response, but I had already seen that DLL, but it seems only to switch primary monitor resolutions. I was hoping to find something functionally similar that switched the secondary only or itself had a selector to choose which monitor was to switch resolution.
Hi All
I found a utility called "Display Changer" from 12 Noon, that seems to work fine. Its a stand alone .exe (dccmd.exe), but have managed to plumb in some string handling to enable command line control over resolution, depth, frequency etc control of the primary or secondary monitors independently from within LV. If someone has a better solution - would love to hear from them.
http://12noon.com/?page_id=80
