I was just wondering if anyone has saved all the files to a library. You run it on the same computer and it seems to work great. Then you take it to another computer, and it can't find a certain file. Just curious, if there is a reason why the files are found.. even though everything is running off the same library.
  • 2 weeks later...
Is it possible that the files it is looking for are part of your LV installation? When you save all files to llb, do you include VI.LIB files?
2493[/snapback]
Thanx, it seems to work now.
But on a different note:
when converting to a previous version, is it possible to use current library functions ie from LV 7.1. Or would I have to convert those with older library files?
