Ton Plomp Posted July 11, 2012 Report Posted July 11, 2012 Since LabVIEW (2011?) has pre and post build VIs we can have hooks into the build process. Has anyone managed to sent a message to the build dialog? I have digged a little in the resource\framework\providers\builds folder but nothing stands out (there is a AB_UI_reply_framework_message VI_, however that needs an unknown queue ref. Ton PS the builder says during the post build VI that it's saving the last VI Quote
John Lokanis Posted July 11, 2012 Report Posted July 11, 2012 What are you trying to accomplish, exactly? I have used prebuild and post build actions to add versioning to unversioned things (like web services) and to modify the installer dialog message so it reflects the version of the EXE it will be installing. Quote
Ton Plomp Posted July 12, 2012 Author Report Posted July 12, 2012 I'm doing this for a source distribution and I try to do the following things: Clean the target path Relink MNU files set the version of classes and libraries make a Mercurial commit Ton Quote
