pankaj Posted October 5, 2012 Report Posted October 5, 2012 HELLO, I have Sub-VI for showing the limit check result that displays the result after a limit check is performed as 0-PASS, 1-FAIL and 2-MARGIN. during the measurement it displays the right valid values but soon after the measurement completes it resets it to 0 even if the measurement was a fail. Can anyone suggect a solution to this problem. thanking you, pankaj Quote
Ton Plomp Posted October 5, 2012 Report Posted October 5, 2012 Well, without the code that will be a hard guess. Maybe you run the last batch without any data? Ton Quote
Prabhakant Patil Posted October 12, 2012 Report Posted October 12, 2012 Can You Share the Code, So It Will help to resove your problem Quote
