samewing Posted November 21, 2012 Report Posted November 21, 2012 (edited) Hello. I would be very grateful if you helped me with this trouble. I tried to supply voltage divider from function generator and to acquire voltage on the second resistor and voltage from generator with oscilloscope in LabVIEW. After compiling the project every time I have the same error (ERROR - 1073807343 Insufficient location information on the device or resource is not present in the system). In field "Resource Name" I've tried to type DAQ::2 or DAQ::Dev2. After this I tried to change device name in MAX, but an error was the same. I haven't find solution of my problem on forum. Can anybody tell me what I've done wrong? Thank you. Edited November 21, 2012 by samewing Quote
asbo Posted November 21, 2012 Report Posted November 21, 2012 It sounds like the device is either damaged or not connected to your computer properly. I'd recommend reviewing NI ELVIS: Resources for Measurement and Instrumentation and NI ELVIS II Manuals to make sure you have it set up correctly. Quote
samewing Posted November 22, 2012 Author Report Posted November 22, 2012 It sounds like the device is either damaged or not connected to your computer properly. I'd recommend reviewing NI ELVIS: Resources for Measurement and Instrumentation and NI ELVIS II Manuals to make sure you have it set up correctly. But it works, when i do it not with LabVIEW. When I launch VIs from Start->NI->NImx->Instruments, it works correctly. Quote
