Slider return to default when released?
In conjuction with the lever mentiond on my previous post:
The harder the accelerator is pressed, the faster the car accelerates. This will be illustrated with a Tachometer (RPM). When the accelerator is released, the car will decelerate.
So a ramp up/down function is needed??
:headbang:
Is there a way to make a slider control return to the default position when released?
The aim is to have a control which acts like the accelerator of a car.
When released, it will spring back to 0.
Thanks
Jason
2736[/snapback]
If you use a Event structer associate with your slider, i think you can do that. Use the mouse up event. i hope this example can help you.
bye
Download File:post-645-1101238414.vi
