alexum Posted December 2, 2004 Report Posted December 2, 2004 Hi everybody, I'm a total beginner in labview and i work on an experience that takes data by acquisition. I'd like to create a graph that works online, i mean that update a graph every time that data is coming, puting the value received in x axis, and in y axis, the statitic on the values increasing...The best thing would to have an histogramm, i mean to create also a binning for this graph. I have no idea how to proceed, do you know if it is possible ? Thank you very much in advance for you help. Cheers, Alexum. Quote
Louis Manfredi Posted December 2, 2004 Report Posted December 2, 2004 Hi Alexum: There is a binsort function (From the wiring diagram Functions>Analyze> Mathematics> Probability and Statistics> Hisogram.vi. Unfortunately, depending on your data sample rate and duration of the file, it might be very ineffiecient to display the data in real time as it is collected. A somewhat better approach, that displays real-time, but avoids storing an array of all the samples which continually increases in size, is shown in the attached picture. (I hope the picture is attached, I don't see it in the preview, but I'll get it to you in a later post if its missing.) I know there are more elegant ways to do this, but what I'm showing should be at least reasonably efficient and conceptually simpler for the new user than some of the other approaches. I've left out some details, handling off-scale data, might need to add 1/2 to the scaled data to get bins centered properly, etc. but the sketch should give you a starting point as to how to proceed. I'm working in LV7.1, and don't have 6.1 installed anywhere now, but I think most of the features I'm using are available in 6.1 too. Hope this helps & Best Regards, Lou Quote
alexum Posted December 6, 2004 Author Report Posted December 6, 2004 Hi, I couldn't see your answer before, i will try your suggestion as soon as possible. I thank you very much for your help! Cheers, Alexis Quote
alexum Posted December 6, 2004 Author Report Posted December 6, 2004 Hi, thanks again for your answer. I just to give a try but i have 2 problems. The first one is about the array at the left side. I have created an array as a constant. It has the same aspect than your but not in blue and i cannot see the zeros inside... Moreother, i cannot find how to put the blue arrows on the structure ? And my second pb is that i cannot find the waveform Graph that you indicate. If i click on the pannel Gragh, i don't see any symbol corresponding to yours...?surely, i did'nt look at the right place or something like that ? (i tried also to search in the pannel Waveform). Thank you for your help. Cheers, Alexis Quote
todd Posted December 6, 2004 Report Posted December 6, 2004 Right-click on the array constant to change its "Representation". Right-click on the while loop border to "Add Shift Register". Add a Waveform Graph on the front panel. Quote
Louis Manfredi Posted December 6, 2004 Report Posted December 6, 2004 Hi Alexum: Looks like Todd has answered the questions, but if not or if you have more, let us know! Best Regards, Lou Quote
alexum Posted December 8, 2004 Author Report Posted December 8, 2004 Hi Todd ands louis manfredi, it seems that i don't have the same options with the right click, maybe my version is too old. Anyway, i took an initialyse array instead of and a graph. And it works very well, thanks very much. Only one thing more, on my graph, i can see for each value incoming, a triangular pictured. Do you know if it is possible to have a rectangular instead of ? Thank you very much, Cheers, Alexum. Quote
Louis Manfredi Posted December 8, 2004 Report Posted December 8, 2004 ...it seems that i don't have the same options with the right click, maybe my version is too old.... 2975[/snapback] LV 6.1 should have all the right-clicks you need. One tricky thing with arrays :thumbup: -- if you right click on the array container you get one set of options, if you right click on an array element itself, you get another. (In order to change the variable type, you want to click exactly on an array element, not just on the overall array graphic.) In this case, your use of the array initialize is better anyhow, since that way you can more easily (even at run time if you want) change the number of bins in the array. ...Only one thing more, on my graph, i can see for each value incoming, a triangular pictured. Do you know if it is possible to have a rectangular instead of ? 2975[/snapback] You should be able to right-click on the legend for the graph, and pick bargraph display. (See the attached picture.) Then, in a nearby area of the popup menu, select Interpolation>None to turn off the lines between the points. Best luck, Lou Quote
