ATM Sample CLD Exam written with Actor Framework
I may try the CLD test in a couple of weeks. Here's the ATM exam written in LV12 with AF package version 4.1.1.33.
This took me about 4.5 hours (though I had to pause overnight at 2.5 hours). I didn't do any planning at all: code-and-go all the way.
The UI is the only actor. I really wanted to make the file I/O an actor of its own, as well as a countdown timer (so their FPs could be shown during DEBUG==True), but I'm not THAT fast. Overall, I'm happy with it, for the time spent. Comments are welcome.
my ATM AF Solution.zip
  • 4 weeks later...
Interesting to see you implemented the actor framwork to this example. Looks great, i have a very quick try and go through the code. Only found 1 issue:
-Error handling for the user input, when deposit if user input a text instead of number, an error 85 is generated. The problem is that you wired theerror to the input of the "Error cluster from Error Code" vi in the UI.lvclass:Enter Pressed.vi within the Deposit Amount case, so this vi can not execute as you wanted.
Oh, right! In "UI.Enter Pressed.vi". Nice.
A boiler exam attempt is here:
http://forums.ni.com/t5/Certification/Sample-Exam-Solutions-for-Review/m-p/2385580#M738
I've been working on "real-world" code to see if some of the pros, here, might review it - but as soon as I get each piece close to ready-for-public-eyes, I become comfortable enough with it to switch to customer-specific instances.
