Jordan Kuehn Posted May 20, 2013 Report Posted May 20, 2013 I've been working with the Actor Framework for a little while now, and have been watching some of the CLA Summit videos (thanks for those btw!) and I'm wondering what is the best practice for documenting the architecture of a system built with the Actor Framework. In one of the videos AQ mentions that UML doesn't have a representation for this. The class hierarchy gives a small glimpse into what is going on, but doesn't describe how the actors are interacting and the messages that are being passed between them. I gave the Symbio tool a quick glance and it didn't immediately seem to provide the outline I was looking for. I want to be able to generate a diagram quickly and easily that describes the architecture so I can hand it to someone and say this is how things work. I can create something by hand that is UMLish but I'm wanting to ask all of you guys to see what your approaches have been. Quote
lvb Posted May 20, 2013 Report Posted May 20, 2013 The UML Sequence Diagram is pretty useful for documenting Actor interaction. See the example I created at https://decibel.ni.com/content/message/46192#46192 for an example. There is also a LabVIEW implementation of this at https://decibel.ni.com/content/docs/DOC-28748 Quote
Jordan Kuehn Posted May 20, 2013 Author Report Posted May 20, 2013 Both of those look good to me. From your response I take it that there is no consensus yet though. If I were to go and make a one-off diagram, it would likely look something like what you made in your example, but if there is a 'right' way to go about doing this I'd like to conform to a standard. If one doesn't exist, it should. Quote
