3D Perspective from a 2D map
pakopon
Hello everybody,
I don't know if this post should be here, but my program is a Real Time Localization Algorithm, so here we go. Up to now I can localize a Robot in a simple 2D map but I want to create a 3D prespective like in the attached image in Labview (the perspective of the image was also made in Labview), and I want to ask you, what would you use? I was thinking on a 3D mesh and use the blueprint of the building as texture. But, I was told that in Labview there's a really powerful tool called Robotic Environment Simulator (that I have installed) that can be used to simulate a custom 3D environment.
Anyone has dealt with this problem before?
Greetings and thanks in advance.
post-35621-0-67100300-1374051230_thumb.p
  • 2 weeks later...
