pneumatic cylinder
Hi Lava's,
I have an application with pneumatic cylinders. I want used LVOOP, because in the future it will better for reuse code.
Each cylinder has 2 sensor and 1 pneumatic valve. Sometimes has 1 or 2< sensors but now i need solve standard construction.
Class cylinder has attributes:
- origin enum(byDef, bySen) specifies how to init (by default or by sensors)
- default (bool)                      default position cylinder
- direction (bool)                   direction of movement
- actual (bool)                       actual position of cylinder
- timelimit (num I32)              time to carry out
- timeout (bool)                     time has elapsed
- retry (bool)                         allow retry if was timeout
and methods:
Create()
Destroy()
Init()
CheckPosition()
Move()
Retry()
I need help with implementation state machine in to class.
cylinder_state.pdf
class.ZIP
It is a little unclear what you need. The state diagram you attached appears to just correspond to the different methods in the class. What exactly are you struggling with?
Hi James,
I want create universal class for control pneumatic cylinder. My app has 5 cylinder they are work in seqvence. For exaple: i tell in my app "closs gate" and i must chcek position, if is good - move the cylinder, if is not good then chceck time if is timeout and allow retry - execute RETRY and then chceck position. Position corect - move a cylinder to desired position.
Seqvence cylinder: Check position -> Move -> Check position then cylinder report task done and app go to the next STATE in state machine.
I have methods for this steps and i dont know how to implement in my app. My app has 2 controlls section ( pneumatic & hydraulic ) pneumatic cylinder manipul with part in machine and hydraulic testing this part.
PS: so sorry for my english (:
HY72100.00_RVS pracovisko kpl..PDF
