Deploying Classes to RT -- Sometimes broken run arrow.
So, I'm seeing some weird behavior where I will deploy code to RT and run, then I'll make some changes and it will prompt to save and redeploy a class library. There is no broken run arrow initially, but the deploy will error and when I click OK, I will then have a broken run arrow. I have traced this to classes that have broken VIs that are either 1) unused or 2) diagram disabled.
If I close and reopen the project, the issue goes away and I can deploy. Then, sometimes it goes through this cycle again. It's not that big a deal, but is a bit of a hassle. Anyone know the reasoning for this and/or have any suggested workarounds?
Edit: I should add this isn't a build and deploy of an EXE, but is just clicking the run arrow in the development environment.
Edited by for(imstuck)
