failed to start debug server
Hi all,
I have a problem debugging applications executables on a remote desktop.
I have created a very simple vi to test the issue.
It contains only a while which generated random numbers every 100ms.
The vi is created in LV2013 and the development machine is running windows 7
I have generated an installer the includes the necessary runtime.
For the executable the ´enable debug´ is on.
The remote machine in running windows xp sp3.
I have checked and can confirm that the NI service locator is running.
Also I have manually added port tcp 3580.
When I first executed the .exe I got the popup to unblock the application in the firewall.
I choose the unblock option.
However after all these things I still get the error `failed to start debug server´ on the remote machine.
Does anyone  know a solution to the problem.
many thanks.
