Local Variables or Property nodes?
Im sending strings via serial between two vi's on separate PCs.
The string is made and broken down from and into property nodes(.value). I was wondering if local variables are any quicker?
Or is there any difference at all?
Thanks
Jason :blink:
3428[/snapback]
I'm not sure which is faster. I am guessing local variables would be, since property nodes probably have more overhead.
Another option would be to use queues. Even though they appear in the 'Advanced' pallete, they are really not that difficult to use. (you can use them kind of like a buffer that can be accessed from anywhere in your program)
John
Thanks
Jason :blink:
3428[/snapback]
I suspect that you are asking this question because you are having speed problems. Relatively speaking, any internal data passing method you choose will be light years faster than your serial connection. Local variables would be faster and queues mentioned by @johnRH would be good as well but none of these changes will give you "noticable" speed improvements.
  • 1 year later...
For completeness sake, here's an article on the difference between Value Property Node and Local Variable:
http://digital.ni.com/public.nsf/3efedde43...47?OpenDocument
Regards,
Khalid Ansari
The NI expantion was definitely a little over my head. My understanding is that if we are working within a single VI that local variables are quicker for the PC to handle than a value property node. Thanks!
You are correct. Property nodes require a switch to the UI thread. Local variables do not. As a result, locals should be faster. I just skimmed the liniked article, but this fact didn't appear to be mentioned in there.
J
