String to Hex conversion?
Hi all,
I'm having a bit of trouble converting from a String to the same value in Hex.
E.g. -
I have a text file, with which I store HEX values in a String format.
I read these values into my app in String format, but I need to convert these back into Hex format for my app to work properly.
So basically, if I read in 8D from a text file, I need to be able to write 8D (in hex) through the serial port.
The generic String to Hex conversions do not seem to do what I need them to do.
If anyone has any ideas, that would be greatly appreciated.
Cheers,
grmc
Well, it's not clear to me what you mean when you say "HEX values in String format".
Does this mean your 8D from file is 8D ASCII or Binary? In other words, if you open the file in notepad, does it show an 8D or a non-printable character?
If the 8D is stored binary, then you don't have to do anything to it to prep it for the serial port.
If you haven't noticed the option, the hex and normal display mode options in the string indicator pop-up menu will help you out.
If it's stored as an ASCII 8D, then you need to use scan from string to convert to an int and then type cast it back to a string. Optionally there are the byte array to string and string to byte array primitives that may be of some help.
Randy
post-767-1105583260.jpg?width=400
Randy
3488[/snapback]
When I open it in notepad, it reads 8D
I had a lot of trouble attempting to convert it and typecast it to the value I wanted, so I created this vi which does the trick, albeit in a very backwards fashion!
Surely there has to be a faster / simpler way than this!
Download File:post-854-1106017813.vi
3559[/snapback]
You were basically on the right track, although I think this is a bit more straight-forward.
Randy
Download File:post-767-1106019390.vi
Randy
3560[/snapback]
Excellent!
I was sure there would be a better way!
Thanks a lot Randy :)
