Does the SelectList propery of a panel work?
Hi guys,
In order to get the selected controls of a FP, I thought to use the SelectList property of the panel of the FP. But, even though I have many controls selected before running the VI, the property doesn't return the references of the selected controls. It returns an empty array of references. If this property doesn't do what I was expected it have done, how can I get the selected controls of a FP before running the VI? Or How can I get the selected controls of a FP which is not running?
Once a VI is reserved for execution (or running, which is the same thing practically) the selection list is always cleared - selections only exist in edit mode. To use the Selection List[] property, you have to open a reference to a VI which is in edit mode, which you can do by using either the Open VI Reference primitive or the New VI primitive, which will create a new VI. The property is very useful for performing operations on the selected items.
Attached is the template I usually use if I want to write some quick code for manipulating multiple objects (LV 2009) - it get a reference to the VI you're working in. I believe it was a quick mod from something Norm posted.
Scripting.vit
Ok... guys,
I understood! The mistake was to try to get the selected controls from the FP of the VI where there was the code. It was enough to call the code as subvi from an external vi passing the reference of the vi where there were the selected controls using the "open vi reference" function. And the code started working!
Thank you YAR for the advice!
