Ano Ano Posted November 20, 2013 Report Posted November 20, 2013 Hello, I am trying to make changes in the mathscript codes in an old & rather large vi with many subvi's. These mathscript codes are many & everywere and I am wondering if there is a way to "probe" the main vi & find where they are (or how many are there) so that I will not miss a few in the process. Thank you in advance, Quote
Darren Posted November 20, 2013 Report Posted November 20, 2013 Open your main VI, press Ctrl-F, select "Objects", and specify a MathScript Node as the item to search for. Assuming your application doesn't call any dynamic VIs, and you have the "Search Scope" set to <All VIs in Application Instance>, this should find all the MathScript Nodes in your application. Quote
