Set Texture problem
Hello all.
I have a VI where Setting horizontal Wrap mode to repeat makes a dark area where the sphere has no texture disappear, but I want to understand why the image is not completely wrapped around the sphere when this is set to Clamp and what I can do to fix this issue. I don’t want to repeat the texture to fill to dark area.
See attached example vi.
Many thanks in advance.
example.viFetching info...
Not in LV 2012 they're not.
The folder  is there, lots of other VIs are there but your "Set Texture" Poly and the "Rotate Z axis.vi" are not included.
I do actually USE the 3D Picture control so I certainly have the functionality installed in LV 2012.  Can't you simply save the full hierarchy?
