Vickys Posted December 19, 2013 Report Posted December 19, 2013 I am creating a scripting VI which would semi automate the process of creating a user interface from a ppt slide. I was able to add frames to the event structure placed in the scripted VI's block diagram but I am not able to add events to corresponding frames. Please let me know how this can be done. Thanks, Vicky Quote
jcarmody Posted December 19, 2013 Report Posted December 19, 2013 There is a recent discussion on NI's forum that might help. This idea on the Idea Exchange says that configuring Event cases is implemented in LV2013. Are you using 2009? Quote
Darren Posted December 19, 2013 Report Posted December 19, 2013 In LabVIEW 2013, you can check out the following shipping example to see some snippets of scripting code that modify the configured events in an Event Structure: LabVIEW 2013examplesApplication ControlVI ScriptingStructuresVI Scripting with Structures - Event Structure.vi Here's a screenshot of the applicable part of the example's diagram: Unfortunately, this functionality is not available in LabVIEW prior to version 2013. Quote
