Continuous waveform changing frequency
  I have a problem with my signal generation Vi.
I use a Ni PCI-6221 board to generate arbitrary waveform.
In my application i need to change waveform and frequency on the run and the next waveform MUST start after the last point of the first one.
I attach an example of what i need to do. Don't care about the shape of the waveform bout only the frequency.
As you can see in the exampel when i change waveform the new waveform immediately start truncating the waveform in execution.
I need the new waveform to start at the end of the first one.
NOTE: I MUST use continuee samples or regeneration 'cause i could not be fast enough to write continuously the waveform when i generate 100hz waveform or similar.
could anyone help me?
Prova2.zipFetching info...
