Gribo Posted December 27, 2013 Report Share Posted December 27, 2013 (edited) Hello, Following my previous attempt with Google maps, Here is a websocket based link between LV and Google maps. Websocket class by S.Marlow http://evexiallc.com/index.php JSON API by drjdpowell Javascripts and demo application are based on the Webpanel demo application. Instructions: 1. Obtain a Google maps API key. 2. Edit the WP_Googlemaps.html and add the key to the relevant script tag. 3. Start the demo vi (google maps demo.vi) 4. Open the WP_Googlemaps.html with a modern browser. I have tested it with Chrome and Safari on iPhone 4. You might have to point to the correct path of some VIs, they are included in the vi directory. gmaps_websockets_LV2013.zip Edited December 27, 2013 by Gribo Quote Link to comment
Gribo Posted December 28, 2013 Author Report Share Posted December 28, 2013 Should I create a new entry into the un-certified repository? It will make it easier to update the file. Quote Link to comment
Abhishek Agrawal Posted July 26, 2015 Report Share Posted July 26, 2015 Hey! I am trying to use your web socket example. When I run the program, it doesn't show any map. I have never used web-sockets before so may be I am doing something wrong. I need to be able to show flight of a weather balloon on google maps. I am getting getting GPS coordinates from serial port. Quote Link to comment
Alex Evenson Posted February 1, 2016 Report Share Posted February 1, 2016 Hi, great program - exactly what i was looking for to get full google maps functionality in Labview.I'm trying to use this to track an autonomous vehicle using co-ordinates from its GPS sensor. I've tried reusing the case structure to have the vehicle's co-ordinates center the map, and have a polyline of its path from beginnning of movement, but I've had no success so far.Do you think the best way to do this would be a pair of while loops for 1) Updating center co-ordinates, and 2) Sending co-ordinates every 2s to create a continually updating polyline to replace the case structure? ideally i want to keep some of the case structures manual inputs. Quote Link to comment
