David Boyd Posted January 23, 2005 Report Share Posted January 23, 2005 I have ZERO experience with PDAs. I just may have to change that based on a 'blue-sky' conversation I had at work the other day. What's the current PDA of choice capable of supporting an NI PCMCIA DAQ card, preferably with WiFi built in? Thanks for replies, Dave Link to comment
Torque Posted July 11, 2005 Report Share Posted July 11, 2005 I have ZERO experience with PDAs. I just may have to change that based on a 'blue-sky' conversation I had at work the other day.What's the current PDA of choice capable of supporting an NI PCMCIA DAQ card, preferably with WiFi built in? Thanks for replies, Dave 3640[/snapback] Based on my experience of the last 8 mos, I would discourage any attempt, beyond the most elemental, to use LV PDA with DAQ. But, if you must, the HP iPAQ 5550 (and a few other models in the series) is compatible with HP's expansion pack accessory. The one we use contains its own battery and 2 PCMCIA slots. I've got a CAN card in one slot and a 6062E DAQ card in the other; together they draw, according to their specs, about 700 mA! Needless to say, the battery lasts about 15 mins before the PocketPC OS pops up a box saying batt is critically low (i.e. 30% charge) and it is being disconnected! At this point, the cards lose power, and, again, according to NI's specs, the analog input impedances may decrease from 1 GOhm to as low as 800 Ohms (if I remember correctly). This particular PDA has Bluetooth built in, but accommodates WiFi in its SD memory slot. If you go down this road, be prepared for dark, cloudy skies. Link to comment
Please sign in to comment
Sign In Now
