Hossein Posted February 4, 2014 Report Posted February 4, 2014 hello to the all please help me to creat the vi for testing the centrifuge pump (bench test) excuse me for my lanquge is not good thank you Quote
Hossein Posted February 5, 2014 Author Report Posted February 5, 2014 no any own help me! I want to test the performance curve pump with lab view thank you Quote
jcarmody Posted February 5, 2014 Report Posted February 5, 2014 You really haven't provided any information. What hardware are you using? What have you tried? What isn't working? Your language is fine. Quote
Hossein Posted February 5, 2014 Author Report Posted February 5, 2014 ok thank you Mr jcarmody for your answer .Already icreated some infirmation with lab view for example and question in the university but now i want to design a bench test fo test the performance curves of centrifuge pumps and i force to sensing the flow perssure Npsh & .... for graph the curves for example this bench test thank you Quote
ned Posted February 5, 2014 Report Posted February 5, 2014 Does the pump in your picture connect a computer somehow? If so, using what hardware? What values can you measure on the computer? What parameters can you control from the computer? What should the graph look like when the program finishes a test? Can you create a VI that generates the right type of graph using simulated data, instead of reading it from the pump? That might be a good place to start. Quote
Hossein Posted February 5, 2014 Author Report Posted February 5, 2014 (edited) hello Mr.ned thank you for your answer I think that I can do it(create the simulation graph with simulated data) but I dont know what hardware and what type sensor might be used and I since dont use the daq instrument systems parametrs are flow(debi)/ pressure /cavitation the graph migh look like this picture thank you Edited February 5, 2014 by Hossein Quote
ned Posted February 5, 2014 Report Posted February 5, 2014 What parameters do you need to measure in order to generate the data for that graph? Make a list. For each parameter, what type of sensor will you use for that measurement? Does that sensor already exist somewhere in your system? How will you get the data from the sensor into the computer? If you do not currently have any sensors and data acquisition equipment, then how will you make the measurements? We cannot tell you what equipment to purchase for this purpose, you will need to research for yourself. Quote
Hossein Posted February 6, 2014 Author Report Posted February 6, 2014 ok Mr.ned (if God wills) I make the chek list of all parametrs and all sensor of them but I dont can make list of equipment and drivers then please help me fo create the algoritm of vi I am thankful that spend your time got to me Quote
ned Posted February 6, 2014 Report Posted February 6, 2014 Can you explain, in words, what the algorithm should be, even in very basic terms? Then we can talk about how you would do it in LabVIEW. Quote
