alexum Posted February 2, 2005 Report Posted February 2, 2005 Hi, Doesn anybody knows if it's possible to write an interface in labview and to call a visualc++ application by clicking a button ? Thanks very much in advance for any help! Cheers, Alexum Quote
Aitor Solar Posted February 4, 2005 Report Posted February 4, 2005 Doesn anybody knows if it's possible to write an interface in labviewand to call a visualc++ application by clicking a button ? If the application is compiled, just use the 'System Exec' to launch it. But that seems too easy, so it's sure I'm missing something in your question ;-). Saludos, Aitor Quote
alexum Posted February 8, 2005 Author Report Posted February 8, 2005 If the application is compiled, just use the 'System Exec' to launch it. But that seems too easy, so it's sure I'm missing something in your question ;-).Saludos, Aitor 3771[/snapback] Hi, Thanks for you answer. you didn't miss something because i didn't know this facility. I tried to use it but without success. what i have done is simply put as a constant for the command line test.exe (the name of my executable) and put as constant for the directory path D:\ (where test.exe is). But when i execute it, i have the message: error 2 : the exec command was test.exe Labview: the memory is full NI 488: any auditor detected during the write Have you got an idea what i could do for solving the problem ? Thanks! Alexis Quote
Aitor Solar Posted February 8, 2005 Report Posted February 8, 2005 Don't use the "working directory" input, put all the path in the command line. I have attached a simple image of what I'm saying, let's hope I have done it right Quote
alexum Posted February 8, 2005 Author Report Posted February 8, 2005 Don't use the "working directory" input, put all the path in the command line. I have attached a simple image of what I'm saying, let's hope I have done it right 3803[/snapback] Hi, effectively, it worked! Thanks very much! Alexis Quote
