allowmultipleinstances=TRUE with web services
Hi all, I have been playing around for days trying to solve a seemingly simple problem: In 2013 Web Services, the port is set in the build spec. However, when running multiple instances, the ports need to be different between instances.  There is a property node for setting "websrvr.port"  but it doesn't seem to have any effect.
Has anyone had any luck setting the Web Service port programmatically, or from a command line argument? Right now this is a huge blocker for being able to set up web services at all, so I appreciate anyone's thoughts.
Shot in the dark: try setting WebServer.Active property to false before setting port, then activate it again. Maybe it will restart with new configuration.
