eberaud Posted October 8, 2014 Report Posted October 8, 2014 For the last 3 years our application has been maintained in LV2011. We have recently decided to migrate it to LV2014 so I am currently testing the sources (and executable) in LV2014 to make sure everything still works. I noticed that when I run the application in the sources, the main HMI (which is the start vi) displays the menu and tool bars even though the appearance settings are such that it shouldn't be displayed. Plus it's not like they are really activated either since I can't click on anything, it looks like a pure display glitch. In addition, as soon as I resize the vi, they disappear and the HMI looks the way I expect it. The same thing happens with the executable, except the area corresponding to the menu and tool bars displays the Windows desktop instead, like if you could see through the VI... Once again, things get back to normal when I resize the VI. I've never seen that with previous versions of LabVIEW. Could it be a bug introduced in LV2013 or LV2014? Have you ever heard of somebody having a similar issue? Thanks! Quote
Rolf Kalbermatter Posted October 10, 2014 Report Posted October 10, 2014 For the last 3 years our application has been maintained in LV2011. We have recently decided to migrate it to LV2014 so I am currently testing the sources (and executable) in LV2014 to make sure everything still works. I noticed that when I run the application in the sources, the main HMI (which is the start vi) displays the menu and tool bars even though the appearance settings are such that it shouldn't be displayed. Plus it's not like they are really activated either since I can't click on anything, it looks like a pure display glitch. In addition, as soon as I resize the vi, they disappear and the HMI looks the way I expect it. The same thing happens with the executable, except the area corresponding to the menu and tool bars displays the Windows desktop instead, like if you could see through the VI... Once again, things get back to normal when I resize the VI. I've never seen that with previous versions of LabVIEW. Could it be a bug introduced in LV2013 or LV2014? Have you ever heard of somebody having a similar issue? Thanks! I've seen similar things occcasionally also in at least LV2013 but nothing that I could pinpoint and so far I think only in applications I received from others and most likely also were originally from an earlier version. Quote
Val Brown Posted October 10, 2014 Report Posted October 10, 2014 (edited) I've seen similar things occcasionally also in at least LV2013 but nothing that I could pinpoint and so far I think only in applications I received from others and most likely also were originally from an earlier version. I've built EXEs from code that was migrated -- and updated -- along the way since LV 6i and I've not seen this kind of issue in either 2014 0r 2014. Edited October 17, 2014 by Val Brown Quote
eberaud Posted October 14, 2014 Author Report Posted October 14, 2014 Good to hear it's not just us... Even if you couldn't pinpoint the cause, do you by any chance have any idea how to fix this? Quote
mgunning Posted October 17, 2014 Report Posted October 17, 2014 I've just upgraded from LV 2012 to LV 2014 and have come across a similar weird drawing issue with the toolbar and menu bar. I have a VI where the toolbar and scroll bars are set to invisible, FP window non-resizable. When I run the VI, there is a white strip around the VI where the toolbar and scroll bars would be if they were set to be visible. If I set the window to be resizable, I get a double menu bar, only one of which is operable. (Tried to post pictures of these but LAVA didn't want to accept them). I've managed to fix the problem. In VI Properties >> Windows Run-time Position, I had a custom window position and panel size set. If I turn of the custom panel sizing by ticking the Use Current Panel Size box, the problem goes away. Quote
eberaud Posted October 20, 2014 Author Report Posted October 20, 2014 I fixed my problem by adding twice the same property node right at the beginning of the VI execution: Read the Window Bounds property and Writing it with the exact same value. It's transparent to the user so that's acceptable, but of course I'd prefer a real fix than a workaround... Quote
Mike Le Posted October 21, 2014 Report Posted October 21, 2014 How complicated is your block diagram? Have you tried starting a new blank VI and recoding the problematic VI from scratch? Quote
eberaud Posted October 22, 2014 Author Report Posted October 22, 2014 That's our main VI, its diagram is quite complicated, so recoding the whole VI is not really an option unfortunately Quote
Mike Le Posted October 23, 2014 Report Posted October 23, 2014 Well, something that shouldn't work but might: have you tried copy/pasting your entire diagram into a new VI, then executing that VI to see if the problem recurs? Quote
eberaud Posted October 23, 2014 Author Report Posted October 23, 2014 The thing is that it's also the main HMI, so it's full of splitters, subpanels, and so on. Since I already have a workaround, I might wait quite a bit before doing this test. Thanks for the idea though, I'll keep it in the back of my head... Quote
