bodopoq Posted December 10, 2014 Report Posted December 10, 2014 (edited) When using ChirpZ transform of LabVIEW(The example itself provides) to refining the spectrum, I found a strange thing. When the frequency is very big and the range is small together with a not small number of ChirpZ transform, Error happened(very bad spectrum and wrong frequency ChirpZ's result is)! Nothing is wrong with the examples(I've scripted other VIs to verify this), and this error didn't happend using MATLAB. So I believe that is a bug of LabVIEW!!!(Not Sure yet of course). I Need Help! Is there any error? Or is there a bug of LabVIEW's ChirpZ tansform? I've already uploaded the codes and screenshot.May you have a look. Chirp Z Transform Configuration.viFetching info... Multi Tone Signal Generation.viFetching info... Spectrum using Chirp Z Transform.viFetching info... Edited December 10, 2014 by bodopoq Quote
bodopoq Posted December 12, 2014 Author Report Posted December 12, 2014 Met this problem for a long time, and wait for the NI Technical supporter's final feedback for a long time. Need an immediately solution. Maybe anyone who knows a better way to refine spectrum, may you gave me a help Quote
