Stop execution of VI
Hi All,
I have a VI which opens up a front panel of another VI depending upon the selection. but the problem I'm facing is as soon I execute the VI it starts executing the selected VI and I don't want that to be happen so i'm wondering is there is any way so that I can stop execution of that VI unless I press the run button.
Thanks,
Ravi
  RaviPaike said:
Hi All,
Thanks,
Ravi
4102[/snapback]
Ravi,
If I understand your problem correctly, you have a subvi that executes when you execute the main vi this subvi is in. To prevent his from happening you need to right click on the subvi and select "Subvi Node Setup". Make sure that none of the options are selected. (see attached image).
I hope this helps,
Mike
post-283-1109872714.png?width=400
Hi Mike ,
Thanks for the reply .Thing is I want to open a front panel whenever the VI gets called but I don't want to execute that. so I was wondering if there is a way around it.
Thanks,
Ravi
Hi Ravi:
Perhaps application control menu>Invoke Method>Open FP will do what you want.
post-1144-1109907891.png?width=400
It isn't really possible to "call" a sub-vi without executing the code, but this will open a vi's front panel from another vi, without actually calling the vi whose panel you open.
Hope this helps.
Best Regards, Louis
  Louis Manfredi said:
Hi Ravi:
Hope this helps.
Best Regards, Louis
4108[/snapback]
Hey Thanks Louis it works
Ravi
