Kauzig Posted April 24, 2015 Report Posted April 24, 2015 Hi I have got a Keithley 3706A. It works pretty well to measure with LV. I have to measure the same channel for several times. I managed this without any troubles but they relay is always switching for no reason. Cause this relay has a lifespan it will be a big problem after some hours, so I'm searching for a simple solution to measure one channels for x times without switching. Hope some one can help me. sincerely Kauzig PS: Attached file is a simple measureexample Keithley3706Example.vi Quote
ensegre Posted April 27, 2015 Report Posted April 27, 2015 Usually these instruments operate relays when they switch ranges, which happens for instance when you measure in some autoscale mode; or when ouputs are activated; both can be avoided for continuous measurement with a proper approach (e.g. -- determine the proper range once and repeat a fixed range measurement then). As such your question is instrument and not LV specific. Quote
