viSci Posted May 24, 2015 Report Posted May 24, 2015 I have hear of the zero pixel cluster boarder but could not find something similar for an array. My objective is to build a numeric table-like array. So far the best I can do is: Quote
viSci Posted May 24, 2015 Author Report Posted May 24, 2015 Ok, answered my own question. It does work if I use a classic simple numeric instead of a system numeric and set the foreground color to transparent. Quote
ThomasGutzler Posted May 24, 2015 Report Posted May 24, 2015 I quite like the system palette for creating a clean fuss-free GUI. Especially if you have more than one indicator, which will make you run out of space with the shiny silver things Quote
GregSands Posted May 25, 2015 Report Posted May 25, 2015 (edited) The main problem with the System controls is that the color cannot be changed, nor parts made transparent (this can also be a benefit, depending on your point of view). I quite like the frameless Silver controls which are clean and fairly customizable. Here's an example creating numeric tables with different Array enclosures: As another example, I made a group of cluster arrays in this thread on the dark side. Edited May 25, 2015 by GregSands Quote
