problem with array and text file
Use Read From Spreadsheet File.vi twice, once for each file. Index out first column of both resulting arrays, build new array using "Build Array" primitive. Probably you need to Transpose as well.
But if the time stamps are to be connected to the measurement values, which looks to be the case, I would bundle each time stamp with the corresponding measurement value into a cluster and then have a 1D-array of those clusters.
  • Like 2
in this program i don't want text be by row i want be column
Answer:
Or even better:
  • 2 weeks later...
