Daryl Posted April 25, 2016 Report Posted April 25, 2016 (edited) Is it possible to make a cluster icon small (on the block diagram) like the error constant when you select "View Cluster as Icon"? Doing it the same way as a regular VI does not work. Edited April 25, 2016 by Daryl Quote
ensegre Posted April 25, 2016 Report Posted April 25, 2016 (edited) You mean a typedefd one, I guess. I'm seeing that in LV15 all plain cluster BD constants turn into small icons. One could argue that if it was, it would be a non-self understood custom BD glyph. At that point, would a subVI with a custom small icon and providing the constant cluster output, be an acceptable workaround? Edited April 25, 2016 by ensegre Quote
Michael Aivaliotis Posted April 26, 2016 Report Posted April 26, 2016 I don't think there is. it looks like if you create a small icon, it forces the full square size on the diagram and the blank space turns grey. Quote
Daryl Posted April 27, 2016 Author Report Posted April 27, 2016 (edited) On 4/25/2016 at 11:35 AM, ensegre said: You mean a typedefd one, I guess. I'm seeing that in LV15 all plain cluster BD constants turn into small icons. One could argue that if it was, it would be a non-self understood custom BD glyph. At that point, would a subVI with a custom small icon and providing the constant cluster output, be an acceptable workaround? Actually yes. This is a good idea -thanks. (I don't know why I didnt think of it ) Edited April 27, 2016 by Daryl Quote
