about wavefrom chart property or invoke function
I have just developed a demo vi about waveform chart
target: 1.the wavefrom chart must zero cleaning when vi load
            2.the wavefrom chart must show three line( upper,value,lower), the value is generated by random feature, there are 300 test point totally. if the value out of upper and lower ,will lit alarm led
            3.get image from wavefrom chart, and save as bmp format
issue: in first step , I can not zero cleaning the wavefrom chart
        in last step, I can not save the image
could you help me to solve the issue??
wavefrom chart.vi
Hi agiletvee,
First thing is you need clear history of wave form chart
the image can be saved using export image invoke node
i have modified your vi according to your requirement check it out
wavefrom chart.vi
Edited by venugopal
add one more vi
