pawhan11 Posted October 22, 2016 Report Posted October 22, 2016 I have stared using OOP in LV some time ago, and there is something that I don't undrestand. When I modify 1 class VI all class members are recompiled and also modified despite of fact that I haven't touched them. This becomes a serious problem when using source controll, I am pushing hundreds of VIs to the server and without comments I can not tell which VI was modified. Is there a way around that? When programming without classes I never had this problem. I am using GOOP from Symbio Cross post from: http://forums.ni.com/t5/LabVIEW/Labview-Class-recompile-problem/m-p/3360728 Quote
Rick S Francis Posted July 5, 2017 Report Posted July 5, 2017 pawhan11, To reduce the changes to your source from recompiling- go to the VI properties General category and check: Separate compiled code from source file When this flag is set LabVIEW saves the compiled code in a separate location called the Compiled Object Cache. The Compiled Object Cache will not be part of your source code repository so a compile will not lead to a change to your repository. -Rick Franics 1 Quote
A Scottish moose Posted July 5, 2017 Report Posted July 5, 2017 I went through the same problem when I started implementing OOP a couple years ago and Rick's answer is the correct solution. Quote
