Labview class recompile and source controll
I have stared using OOP in LV some time ago, and there is something that I don't undrestand.
When I modify 1 class VI all class members are recompiled and also modified despite of fact that I haven't touched them.
This becomes a serious problem when using source controll, I am pushing hundreds of VIs to the server and without comments I can not tell which VI was modified. Is there a way around that? When programming without classes I never had this problem. I am using GOOP from Symbio
Cross post from:
http://forums.ni.com/t5/LabVIEW/Labview-Class-recompile-problem/m-p/3360728
  • 8 months later...
pawhan11,
To reduce the changes to your source from recompiling- go to the VI properties General category and check:
Separate compiled code from source file
When this flag is set LabVIEW saves the compiled code in a separate location called the Compiled Object Cache.   The Compiled Object Cache will not be part of your source code repository so a compile will  not lead to a change to your repository.
-Rick Franics
