Translating VB Code to LabView
I'm Building a production tester that uses a Melexis chip programmer. It came with and Active X toolkit but all the examples are written in VB.
I was able to interpret all the VB code except one part.
The code below scans for connected devices and returns a "Collection pointer"
Sub CreateDevice()
Dim PSFMan As MLX90251PSFManager, DevicesCol As ObjectCollection, I As Long
On Error GoTo lError
Set PSFMan = CreateObject("MPT.MLX90251PSFManager")
Set DevicesCol = PSFMan.ScanStandalone(dtSerial)
If DevicesCol.Count <= 0 Then
MsgBox ("No PTC-04 programmers found!")
Exit Sub
End If
' Dev is a global variable of type MLX90251PSFDevice
I think you have to use for the type input of the variant to data function an array of refnums, because in the VB is the first element selected with index 0 DevicesCol(0).
