Fil_Lab Posted December 1, 2016 Report Posted December 1, 2016 Good morning. I'm new of labview and I would like to call C++ code from VI for my application. I did a C++ project, generate DLL and I call it from VI. It's working on my pc but if I make an application for another pc, the application works but the dll is not working. I installed the c++ redistributable on second pc but I had the same problem. in particular a message error with "error 42" appears. Can you suggest me some check to fix it ? thank you very much for your collaboration Quote
Rolf Kalbermatter Posted December 1, 2016 Report Posted December 1, 2016 1 hour ago, Fil_Lab said: Good morning. I'm new of labview and I would like to call C++ code from VI for my application. I did a C++ project, generate DLL and I call it from VI. It's working on my pc but if I make an application for another pc, the application works but the dll is not working. I installed the c++ redistributable on second pc but I had the same problem. in particular a message error with "error 42" appears. Can you suggest me some check to fix it ? thank you very much for your collaboration You did redistribute the No Debug version of your DLL? The Debug version will link to a different C runtime library that is not redistributable to other computers and only works on PCs where you have the Visual C compiler installed. Quote
Fil_Lab Posted December 2, 2016 Author Report Posted December 2, 2016 It works! thank you very much. Have a nice day. Quote
