Obtaining associated Control references from ControlTerminal References
parsec
I have a sequence structure that I am using as a container for a number of unconnected controls and indicators (they are interacted with by reference only).
I am trying to programmatically obtain the references to these controls, but I can only seem to get the references to the block diagram ControlTerminals using the Traverse for Gobjects VI. Does anyone know how I can obtain those associated control references?
A property of ControlTerminal is Control which gives you a reference to the front panel item.
In your case you would need to change the class specifier constant being fed into the to more specific class to ControlTerminal (GObject > Terminal > Control Terminal) and then get the front panel reference from another property node before getting the label's text.
