pathfinder Posted April 11, 2005 Report Posted April 11, 2005 Hello.I am a new user in labview programming and i am very interested for using it.I have a question. How can i build a executable file from a vi ?( my labview version is 7.0)please if you can,explain for me a complete steps for this goal. :worship: Quote
dhuff Posted April 11, 2005 Report Posted April 11, 2005 First, you must have the Labview Application Builder installed, it is an additional package for the Labview development system, it comes with with the more expensive versions of Labview. (Labview Full Development Version, or Professional Development Version) If it is installed, open Labview, and click Tools >> Build Application or Shared DLL. A window should pop up, allowing you to specify files to include and such. The main thing to remember is to click on the pull down menu for build type, and choose Application (.exe) There should be more info on the NI website, search there for more details. Quote
pathfinder Posted April 12, 2005 Author Report Posted April 12, 2005 First, you must have the Labview Application Builder installed, it is an additional package for the Labview development system, it comes with with the more expensive versions of Labview. (Labview Full Development Version, or Professional Development Version)If it is installed, open Labview, and click Tools >> Build Application or Shared DLL. A window should pop up, allowing you to specify files to include and such. The main thing to remember is to click on the pull down menu for build type, and choose Application (.exe) There should be more info on the NI website, search there for more details. 4511[/snapback] ok.Thanks.This is good.But it doesn't work in othes computer,because the other computer hasn't labview program. I want to build a exe file that can work in a computer without labview. Quote
todd Posted April 12, 2005 Report Posted April 12, 2005 When you build the exe, check "Create Installer" then under "Advanced..." button, check "LabVIEW Run-Time Engine". Quote
JustJay Posted July 1, 2005 Report Posted July 1, 2005 Totally new to LabView here, using 6.1 also. I packaged the first program I wrote as an EXE, and included the run time engine as well. After running the installer, I ran the exe that I compiled, and it opened a "Select VI File" box. After choosing the script that I wrote, it runs fine as a stand alone. What did I do, or not do that excluded the full packaging of the file in the exe package? This is the first day of playing with LabView, and I am liking it already! Thanks for your help. My first post on what seems like a killer forum! Jay Quote
i2dx Posted July 1, 2005 Report Posted July 1, 2005 You can find a good manual (as PDF, if you don't like the online help ...) in "your programm files dir"\National Instruments\"your LabVIEW dir"\manuals\appbldr.pdf There is a step by step instruction how to build an application from a VI. What about the script you wrote ? Can you please tell some more details? The exe should contain all the files LV needs to run the application (including VIs from vi.lib, etc ...), therefore LV should not ask 4 missing files ... Quote
JustJay Posted July 1, 2005 Report Posted July 1, 2005 You can find a good manual (as PDF, if you don't like the online help ...) in "your programm files dir"\National Instruments\"your LabVIEW dir"\manuals\appbldr.pdf There is a step by step instruction how to build an application from a VI. What about the script you wrote ? Can you please tell some more details? The exe should contain all the files LV needs to run the application (including VIs from vi.lib, etc ...), therefore LV should not ask 4 missing files ... 5178[/snapback] My problem was more like a lack of sleep. Came in the morning, repackaged the VI as an exe and bam, up and running. Thanks for your response....I am sure that I will have a million more questions! Jay Quote
i2dx Posted July 1, 2005 Report Posted July 1, 2005 got the labVIEW fever ? <BigGrinn> i know that feeling ... Quote
