3D pucture objects overlapping
pawhan11
Hello LV users,
I have been fighting with 3D picture for 2 days and I have stumbeld on the following problem:
I need to display rectangle + text. Text should be always displayed before background when camera moves or is rotated.
I have attached test vi that exports fragment of functionality and shows the problem.  Camera settings and billboarding must be set to values provided in test vi.
Text must be displayed before green box not after like on picture below.
Intresting is when I zoom text is displayed correctly...
Do You have any idea which one of undocumented options in 3D picture might help??
This is cross post from NI forums:
https://forums.ni.com/t5/LabVIEW/3D-picture-control-objects-overlaying/td-p/3720660
test2.vi
If you position objects at the same depth from the camera, you're leaving the choice as to which draws "front" up to rounding errors of the SGL datatype.
Put a minimal depth difference between them.  IIRC, there's a property you can set in order to force this.
@shoneil I have tried that without success. I assumed that item in closer to camera will be displayed(text). Maybe this is related to billboarding? I need text and this green area+ frame to always face camera
test2.vi
Thanks @shoneill this solved my problem.
Another one appeared, I need to zoom in to see displayed text correctly like on attached picture. I want small text to be displayed as well.
Do You have idea about that one? It is good to know that NI made some wrapper around opengl so there is chance to find some documentation :)
The only thing I can think of is to make the text more than a single pixel wide..... Otherwise antialiasing is going to do that to you.  Of course, YOu can try turning off the Antialisaing for the object in question..... "Specials: Antialiasing"
Thanks for reply but it seems Aliasing is not the problem.
People tell about camera perspective :
https://stackoverflow.com/questions/5300888/how-can-i-increase-distance-zfar-gluperspective-where-opengl-stops-drawing-obj
but objects more in the back are displayed correctly. What I noticed it that this is letter dependent. For some letters like A I must zoom a lot so see something, letter E for example I see always even when I zoom out... :)
On NI forums they had discussion about text display problem and PC was blamed. I have tried on 2 machines and this is not HW related.
https://forums.ni.com/t5/LabVIEW/3D-Picture-Text-Display/td-p/2985433
I have tried other fonts but it is unrelevant.
What I found helped int eh past was to generate the text texture myself for application.  By creating a much larger texture than required, resulting in each letter being many pixels wide, the effects you are seeing were significantly reduced.
Shane
Thanks @shoneill I have managed to make this work. For some reason I could not display texture on mesh but simple rectangle works fine in my case.  When I add texture from picture text is always displayed correctly.
Thanks again for help:beer_mug:
