Notifier vs. Generated User-Event w/ Event Struct
I kick off an independent loop using a generated user-event that wakes up a single-event event structure. It occurs to me that I probably could have used a notifier to do the same thing. Are these essential the same mechanisms? The only advantage I can think of to the event structure is it could more easily expand to accomodate other events if my situation required it.
4778[/snapback]
NO! Events are queued, Notifications are NOT. If your processing loop cannot execute fast enough, you might miss Notifications that happen while you are processing them.
  LabVIEW Help - Notifier Operations Functions said:
Unlike the Queue Operations functions, the Notifier Operations functions do not buffer sent messages. If no nodes are waiting on a message when it is sent, the data is lost if another message is sent. Notifiers behave like single-element, bounded, lossy queues.
