Annoying PPL behavior
Porter
I have been transitioning my framework's core libraries to packed project libraries. Unfortunately, the higher level PPLs depend on lower level PPLs, but i think that I've managed to sort out all of the broken connections. Now the issue that is bothering me is that whenever I open a project containing a higher level PPL, I get a bunch of "VI cannot be found on disk errors" that refer to VIs within the higher level PPL.
My initial thought was that the file paths were too long, but that doesn't seem to be the case.
Has anyone else come across this behavior when using PPLs?
It is solved now. I unchecked the exclude PPLs and DLLs in the build spec of LF.lvlibp
And moved the resulting LF.lvlibp to the same directory as the other PPLs.
