FixedWire Posted December 11, 2019 Report Share Posted December 11, 2019 To all the warriors out there a heads up if your computer is suddenly running at 100% CPU. In the Task Manager, the Task Manager process will gobble up any CPU available. I swore it was a virus. A 3rd party tech support knew about this. Turns out a camera did not shut down correctly. To avoid Windows willy-nilly starting a process it likes that will screw up tasks such as frame grabbing response this Windows setting is used. Use PowerShell & run the following: "C:\Program Files\Point Gey Research\FlyCap2 Viewer\bin64\PGRIdleStateFix.exe enable" 2 Quote Link to comment
