carloslaginhas Posted June 15, 2005 Report Posted June 15, 2005 Hello people, i have a critical problem. I'm new working with Lab View 7 and i have two problems. I need to know how can i save my data into a file where my data is recorded for future use. Other question is how can i make a graph of, for example temperature Vs time. The real problem is that i dont know how to put the time running and make a graph with it. This is fundamental to my work and i really need your help. Thanks! Quote
isihra Posted June 15, 2005 Report Posted June 15, 2005 carloslaginhas said: Hello people, i have a critical problem.I'm new working with Lab View 7 and i have two problems. I need to know how can i save my data into a file where my data is recorded for future use. Other question is how can i make a graph of, for example temperature Vs time. The real problem is that i dont know how to put the time running and make a graph with it. This is fundamental to my work and i really need your help. Thanks! 5036[/snapback] Hi Carlos, Lets say you are using Waveform Graph to display your data, you would need to change the X-Scale Formatting by right clicking on the waveform graph and select X-Scale-> Formatting->Select Tab "Format and Precision" -> Select "Absolute Time". Now, you would see system time each time on X-Scale when you send a temperature data to this waveform graph. To store this data use the "Write Waveform to File.vi" under Waveform File I/O palette. Hope this helps. Best Regards, Iqbal Quote
